So there I was playing WoW last night and all of a sudden things starting to get very jerky as in the screen would freeze for 5 seconds then go back to normal for 5 seconds and so on. I did a hard reboot thinking that it would solve the problem but no, runs through the BIOS just as it would normally start to load Windows but instead comes up with an error: 'Cannot find file NTLDR - please press ctrl-alt-del to restart', and the same thing would happen a couple of times, until i turned it on this morning. And there was nothing, no BIOS screen, TFT didnt come out of standby. no beep to say its passed the system tests, just the fans whirring and thats it.
Can anyone make head or tail of what the hell went wrong here? Ive had some problems in the past similar to this which were down to my SATA cables but the problem was solved after a change of cable. Now this, compleltly out of the blue. Whats most likely to be at fault?
Thanks in advance.
Thanks in advance.
