Hi all.
1st post so sorry if this has been asked before.
My main Pc (old Evesham unit) has died. It has been having issues for a few weeks now & it won't start up. The symptons are: I press the power button & the button flashes, but nothing else happens. I have checked inside & when I press the power button, the fans briefly spin (for about 1/2 a second) & then stop. It was working ok, then it would be difficult to start (needed a few prods on the power button to start). Also, sometimes the pc would appear to start (fans whirring) but no monitor activity & very little hd activity. I have unplugged & re-plugged the main power plug into the mobo but with no change. There does not appear to be a LED on the mobo - or if there is it is not lit.
My system is:
Foxconn P9657AA- 8EKRS2H mobo
4gb ddr2 ram
Intel core 2 duo 2.4ghz (I think) cpu
Nvidia 8800 GTS 640mb graphics (the original one from 2007)
Twin 250bg 7200rpm hd's
Soundblaster live value soundcard
600w power supply.
Coolermaster CM 830 case.
Win 7 32 bit upgrade (from vista)
External western digital 1tb WD book drive using USB.
I am hoping it's the power supply, but it may be the mobo.
Can anybody give me any pointers on how to diagnose this?
My system is:
4gb ddr2 ram
600w power supply.
