PC DEAD ?
18 Oct 2002
kent
Last night I moved the pc which will now not boot at all. Nothing has been changed in the pc I have just moved to another room
I must say that when the pc power supply was cut / turned off it would sometimes be a pain to boot.
The only life I see is the PSu fan & HS fan both spin for a second when the power is connteced or turn on and then the front LED just flashes every second . I have doubled checked all connections and everything seem to be fine
There are no beeps and nothing displayed on screen
Hardware
Antec 450w PSU
MSI K8N Neo4 Platinum
1 Gig Ram 2x512- cant remember brand
msi Nvidia 7900gto
3700 AMD
Any ideas ?
thats what I am thinking at the moment
Yeah, I mean you say it had problems starting sometimes when it had been turned off. And now it's not powering on properly (i.e. fans will spin for a split second). Sounds like PSU to me. :(
yeh i was thinking PSU too ... i dont really trust those antec ones ... saying that im using a ezcool which isnt particulary great either but it does the job
