Hi, just need a quick bit of help, my pc has died on me. Self built.
This morning switching it on it got power for a splt second then wouldnt come on, tonight it stayed on for about 5 seconds power went off it, then it came back to life, but there was a slight burning smell so im assuming something has died.
Its an E8400 on a Asus P5q-e with a bfg gtx 260 mc. And has been fine upto now.
Currently it seems to be booting, i get no display on the screens,but there is power going to the G card as the fan is spinning. Given theres power to the mobo and g card im assuming the psu is ok. But ive got no way to check the PCI-e card or a spare pci-e card to test with the mobo. So what do ppl think is wrong? So i can check my warranties and get it sorted. All the mobo fans re working, as is the cpu one, the ram lights are on. And the light up power an reset buttons on the mobo are on fine.
Atm thinking graphics card, seems these gtx 260 do seem to run like a pheonix.
thanks
thanks
