- 19 Mar 2009
- Leicester
Hi all,
Long time since ive posted in here but would be really grateful for some advice as my PC has just died spectacularly and need some help pinning down the problem.
I was playing a game and it just powered off and would not switch on again. Now the system has been stable under current setting for years.
Since trying to diagnose Ive removed GPU and all HDDs/optical drives to no effect. Ive pulled the memory and used one stick on each bank also with no effect. Ive reset the CMOS with no effect.
All the lights are powered up on the motherboard when the system is receiving power and if I try and switch it on with the power button the power light comes on for a less than a second and you can see the fans try to spin but then it shuts off immediately. If I then try the power switch again nothing at all happens unless I turn off the PSU/wall socket after which it will do the above again.
So far I'm thinking mobo, CPU or PSU but ive got no spares to swap out and test on so if anyone can offer any wise insight into which its likely to be I would be most grateful.
Specs:
i7 950 @4ghz
6Gb DDR3 RAM.
Gigabyte GA X58A UD5
ATI 7970
500gb HDD
1.5TB HDD
500gb Samsung evo 850
2x Blu-ray drives
Corsair HX 850W
Many thanks for the advice
Hawker
Specs:
i7 950 @4ghz
6Gb DDR3 RAM.
ATI 7970
500gb HDD
1.5TB HDD
2x Blu-ray drives
Corsair HX 850W
Hawker
