PC Doesn't start 1st time - help pls
7 Jun 2005
SE London
I've got a PC here of the "D" brand, it's about 3 years old. When i "cold" boot it (1st time in the day) it does the BIOS checks and everything, then just before it's going to load up windows it turns itself off.
The second time i start it up, it works fine. Also when i shut it down, then start it up again, there are no problems.
So - only the 1st time in the day (when it's cold) it gives me this problem.
Any ideas what this may be? Should i order a new PC or can this be fixed?
I wounder how much your get at auction for a malfunctioning computer? :rolleyes:
I would guess that the problem you describe is to do with the ram, but you could try updating your bios first, might fix it
Sounds stupid, but have u tried using a different hdd with windows on. If you do have another hdd you can try out use a new ide cable and boot with just the hdd connected.
Here's what I tried so far (without success) :
1. Checkdisk thorough
2. Updated BIOS Firmware
3. RAM test (ubcd)
4. Formatted and Re-installed windows
any more suggestions? Could it be the CMOS battery being on low power? Any other ideas?
