Hi there.
PC was working fine on friday night, come saturday evening I turn it on, but their is no display on my screen, i then notice the HD light stays on constantly, and the motherboard isnt making any normal or warning beeps.
The motherboard is an Asus P4P800 SE agp ( yes yes I know its an oldy
I tried resetting the cmos, also changed the battery with no luck, I unplugged everything aswell and still nothing.
Tried a difference graphics card as well, I did try another PSU but for some reason that would only power the pc for a split second?
I did notice it seems the fan on the graphics card (powered by seperate 3 pin plug, which goes into the motherboard) didnt even spin, so seems power isnt getting through the entire board.
Im wondering if anyone has any idea's on this before i go and order a used p4p800 motherboard
Thanks for any help
)I tried resetting the cmos, also changed the battery with no luck, I unplugged everything aswell and still nothing.
Thanks for any help
