Hi Everyone, I built a new pc recently (Spec in my sig)
However the fan noise is getting to me now and I to do something.
At the moment it runs very cool :
Geforce 7800 GTX Cards run at around 47-50 c Idle and rise upto 60-70 When fully under load (i'm talking about 5 hours of BF2)
The cpu temp idles at 33-35c and rises to 43c at the most, the chipset (fanless let me add) idles at around 37-39c and rises to 44 max when my room is very hot (ie central heating on)
I've got :
1 x 120mm (lian Li supplied) Case fan as the intake, thats running with a molex connector plugged straight into the psu
1 x 80mm (lian Li supplied) Rear Case fan again connected to the psu with a 4 pin molex connector
1 x 80mm (lian Li supplied) Top Case fan, same as above again
1 x 120mm Papst running on a Thermalright XP-120 again connected to the psu with a 4 pin molex connector as the motherboard wouldnt be able to take this anyway on the headers etc.
I might add that I've got 4 (yes 4) hard drives, one raptor and the rest are samsung spinpoints.
The question I want to ask is can I do anything to make the system more quiet as the fan whirring noise is doing my head in.
I've had a look at some fan controllers but they all only seem to take 3 pin plugs, another option would be to use a old pc mods rheobus and cut all the molex plugs off and have them connected using a blocklike connector.
But how much noise will it get rid off I dont know.
Anyone any ideas before I go deaf![Frown :( :(](/styles/default/xenforo/vbSmilies/Normal/frown.gif)
I've got :
