Pc fans work but wont boot
19 Oct 2011
Hi, im new here so forgive me if im in the wrong place. my pc has been having this problem on and off for the last 6 months or so. In the last week or 2 its been happening all the time. Basicly when I hit the power button all the fans start up but it wont boot. I have to reluctantly keep re-setting it untill it powers down and powers itself back up again. That is when it boots. Sometimes i only have to press re-set 5 or 6 times. counted about 20 today :(.
I have done a re-install about 8 months ago, just to speed the thing up. Dont think that caused any probs and dont really want to have to do it again if im not 100% reassured that that will fix it.
My machine is about 4/5 years old. Done a motherboard update yesterday. One thing i noticed is that it only has this prob on the 1st start up of the day. If I shut it down it will boot straight back up again.
Info from belarc advisor....
Board: ASUSTeK Computer INC. P5K SE Rev 1.xx
Serial Number: MS1C76B39301666
Bus Clock: 333 megahertz
BIOS: American Megatrends Inc. 1104 07/07/2008
2.67 gigahertz Intel Core2 Duo
64 kilobyte primary memory cache
4096 kilobyte secondary memory cache
64-bit ready
Multi-core (2 total)
Not hyper-threaded
249.99 Gigabytes Usable Hard Drive Capacity
197.93 Gigabytes Hard Drive Free Space
CD-ROM Drive [Optical drive]
3.5" format removeable media [Floppy drive]
SAMSUNG SP2504C [Hard drive] (250.00 GB) -- drive 0, s/n S0WRJ1PP508282, rev VT100-52, SMART Status: Healthy
2048 Megabytes Usable Installed Memory
Slot 'DIMM0' has 1024 MB
Slot 'DIMM1' is Empty
Slot 'DIMM2' has 1024 MB
Slot 'DIMM3' is Empty
Local Drive Volumes new – volume encryption
c: (NTFS on drive 0) * 83.89 GB 59.59 GB free
d: (NTFS on drive 0) 83.89 GB 56.65 GB free
e: (NTFS on drive 0) 82.21 GB 81.69 GB free
* Operating System is installed on c:
NVIDIA GeForce 7800 GT [Display adapter]
Samsung SyncMaster [Monitor] (24.0"vis, s/n 0003H9MZB02152, November 2010)
Windows XP Home Edition Service Pack 2 (build 2600)
Install Language: English (United States)
System Locale: English (United Kingdom)
Installed: 17/02/2011 06:55:54
Hope this is enough info and thank you so much in advance for help and support.
Mark
Antec are usually decent but I'm still thinking PSU here. Had a similar issue on an old rig and that was the PSU. had to start and restart several times using the power button, once it was up it was solid enough but the inrush current Of all components caused the issues. If you have access to another PSU give it a try.
