Spec of computer:
AMD 3200 (2.0GHz)
Gigabyte K8NXP-SLI
4x512Mb PC3200
512Mb 8400 GT PCI-e
320Gb 7200rpm SATA
DVDRW SATA
500w PSU
etc..etc...
Receive a PowerColor HD 5670 today as a boost to graphics performance, already have a main PC (Mac Mini) but put the above system together from two old computers, now since I received said card I was unsure how to proceed.
I intended to keep both GFX using the 8400 for physx use. Proceeded to remove 8400, enabled the sli mode card as I thought this was needed. Fitted both cards, turned on and nothing.
Removed cards again, set the SLI back to normal and only fittled the new GFX, switched on and nothing.
Revert back to original GFX, switch on and nothing.
This is using VGA as display connection on both cards.
Now when I say nothing I mean no display, HDD activity light flashes for only 2-3 seconds and nothing like the BIOS is waiting for input.
I dont believe there is a BIOS reset button on the motherboard so I disconnected the power and removed the batter for 5 minutes. Having done so did nothing.....
Any suggestions?
AMD 3200 (2.0GHz)
Gigabyte K8NXP-SLI
4x512Mb PC3200
512Mb 8400 GT PCI-e
320Gb 7200rpm SATA
DVDRW SATA
500w PSU
etc..etc...
Any suggestions?
