- 30 Jul 2020
pc specs
motherboard - MSI B450 GAMING PLUS MAX Motherboard ATX
CPU - AMD Ryzen 5 2600 Processor
CPU cooler - stock wraith stealth
GPU -XFX Radeon RX 580 GTS XXX Edition OC 8 GB GDDR5 3xDP/HDMI/DVI-D Graphics Card
RAM -HyperX Predator HX432C16PB3K2/16 Memory Module 3200MHz DDR4 CL16 DIMM XMP 16GB Kit (2x8GB)
PSU - Corsair CX550M/CP-9020102-EU ATX 12 V Power Supply Unit
memory - SanDisk SSD PLUS 240 GB Sata III 2.5 Inch Internal SSD
Western Digital WD10EZEX 1 TB PC Hard Drive
brother brought this pc to me because its been having issues however i cant for the life of me figure them out.
full disclosure this pc had artifacting issues as well as sudden power offs that we never got to the bottom of but stopped happening after adjusting some settings and updating driver. this was over a year and a half ago.
now weve got it randomly refusing to turn on with three long beeps which should indicate a memory issue. leaving it unplugged for a few minutes allows us to actually boot but all mem-tests ive run show that the memory is running fine.
ive double checked the VRAM as well through programs and it also seems fine. so im not sure what im missing here.
the fault is not repeatable and happens purely at random ( brother says its happened 3-4 times over the last year)
i unfortunately dont have any extra hardware handy to test anything in a more substantial way.
just wanted to pick your brains a bit on this one.
