PC Fix Help
31 Jan 2007
Hey,
I am trying to fix a computer which is having problems. I have removed all hard drives, all pci cards (except GPU), optical drives and when I switch the system on I don't see the mobo picture screen or post screen. It doesn't even beep. Also, normally the cpu fan spins up and then as the computer boots the fan speed increases but it is not doing this.
The Motherboard is an Asus p4S800
Can anyone help?
Thanks
Regards,
Neil
If it has more than one stick of ram, try one stick of ram in at a time. As I had this same problem and it turned out to be a faulty ram stick.
Right, an update guys.
I have tried each of the sticks of ram on their own and it still doesn't work as expected.
I have also tried a different PSU unit.
It starts up and gives me about 30 seconds and then switches off and reboots.
Idid manage to flash the bios to the latest bios version throguh the build in easy flash software and that was successful but it still does it's restarting trick.
Any other ideas guys?
Thanks
Regards,
Neil
