PC For Gaming - £1200
27 Jul 2012
Can somebody spec me a machine, mainly for gaming.
The only salvageable parts I have are 1gb HDD, 3gb HDD & BluRay Writer.
I have £1200 to spend. I have a monitor that will utilise 1080p at max but would prefer to eventually shell out for another monitor (outside £1200) if you can recommend one.
Cheers
I can salvage current keyboard & mouse until I can scrape more money together. I have Windows 7 that I can use until I can pay to upgrade to 10.
Hi
Can you recommend another case as currently out of stock.
In addition the case is housed in a wardrobe so may need help with better cooling. Any thoughts, recommendations?
Finally, where it is housed only allows a max 24" monitor. Any recommendations?
Regards
