PC for HD mkv's
18 Oct 2002
UK
Im looking to build a pc for general use & for playing 1080p .264 mkv movies onto my HD tv, my 3200+ struggles......:(
Could you please spec me a pc that will play HD movies without struggling, but also without costing to much either, dual core cpu, mobo with onboard hd audio with optical out to go to my amp, & with plenty of sata connections, ram, a graphics card & anything else i might need, not worried about gaming as i have 360 & ps3 for that, cheers !! :)
My spec in sig plays them fine and I paid £600 with delivery I think, excluding the case/monitors/hard drives. Also if your not a gamer you wont need a 8800GT and could get the latest radeon instead as they are about £100 for basic one I think (My 8800GT was £180 IIRC).
Your sig is much to big, the rules say a max of 4 lines.
Upgrade your 3200x2 to a dual core, sorted. If building new HTPC
2ghz dual core
2GB RAM
ATI 2600 Pro
IR receiver/remote control
HTPC software (XP MCE, Vista MCE, Media Portal, Linix MCE, Myth TV)
C-Media soundcard with digital audio output.
