PC for TV/General Use
18 Feb 2006
Looking to build as cheap as possible PC for a room upstairs, will be used for movies, so needs 250gb + hdd.
Also, will be used for general use and FM2008 most likely.
Whats the cheapest i can get the base for?
Also on top if possible, a wireless keyboard/mouse too.
Thanks for any ideas, so far ive thought about Barebones, E2140, 2GB OcUK, 500gb Samsung and a 7600GT which come to about £300 with a keyboard/mouse and a DVD RW.
Anyway of getting it cheaper?
Or is that the sort of price range you think i should be looking at? Around £300?
Is the 7600GT overkill, or for the price adequate for anything else that may be needed?
8400 GS will be good for HD dvd and it costs less.
Add me to msn
