For the last week or so my PC has started to completely freeze for about 10 seconds, the fan of the CPU speeds up like it's loading something then it comes back to life. The audio after this is distorted and I have to reload my audio devices. I have not installed anything that could be causing this and my PC is the same as it was before the issue started to occur. I was wondering if anyone had encountered similar problems and offer some advice. Thank you for reading!
Specs
i7-8700k @4.8GHZ 1.2v
Corsair Domminator 4000mhz (XMP) 16GB DDR4 RAM
EVGA GTX 1080 FTW2 iCX
ROG MAXIMUS X HERO
Samsung EVO 500GB SSD
EVGA 600 B1, 80+ BRONZE 600W
Corsair Hydro H60 V2
Things I have tried so far
Specs
ROG MAXIMUS X HERO
- I have run memtest64 and it produced 0 errors.
- I have installed my old graphics card and the problem still persists
- I have updated all my drivers using Driver Easy
- I have updated my BIOS to the latest version
- I have removed my overclock on both my CPU and RAM and the problem still occurs
- I have stress tested my CPU and the maximum temperature under 100% load for extended period was 82 degrees. Runs at 34 degrees idle
- Reinstalled Windows 10
- Checked Event Viewer for error reports straight after the freeze and there are no logs recording the problem
