Pc freezes....Constantly Weird..
Permabanned
28 Feb 2006
Hello,
Well I have the rig in my signature, I did have it at 2.5ghz at one point howver its ALL at stock at the moment due to the summer brining temps to about 42 idle anyways.
Erm, well just tried to play some CS:Source, however after 5mins just FREEZED, with the same image constantly there. I restarted machine and the reported temp was 47 degrees in bios.
Tried again, same issue, what do I do? Shall I hoover the dust on the heatpipes of the cpu does that make a difference? It does have a bit of dust there..
I dont think its the PSU, as its a Seasonic S-12 600w, also, this occured before with another psu, on another rig though.
Thanks, help appreciated.
Btw, I am on air cooling, and I have one 80mm YS-TECH fan blowing over the heatpipes of the Arcticc cooling 64 freezer, its on the side panel.
Case : Sunbeam Samurai
Try a CMOS reset - the BIOS may be holding on to an overclocked setting that the system doesn't agree with.
AndyOcUK
OcUK tech
