For the past couple of weeks my pc has started to freeze up. it all started when getting a new sapphire r9 280x. originally i got an asus r9 280x and didnt have the problems apart from it artifacting so hence why i now have a sapphire 280x. sometimes after i reboot from it freezing up my hdd disappears and takes a few resets to get it back up again. changed the sata cable but still have the disappearing trick it does.
i did download hdtune to see if there are errors and it does say "end to end error detection" has failed and also "interface crc error count" needs attention.
full spec:
cpu - amd phenom 2 960t @ 4.0
gpu - saphire r9 280x
motherboard - msi 870a-g54
ram - 8gb corsair 1600 running @ 1333
hdd - 1tb seagate baracuda
psu - ocz 650 watt
5 case fans and dvd burner
i only got the hdd last year but could it be on its way out allready?
could the saphire 280x gpu be causing the freezes, or lack of power maybe?
full spec:
psu - ocz 650 watt
