Pc freezing
10 Jun 2006
Wigan
Hi guys,
Basically if I give my pc the slightest knock it locks up, everything stops working, even the mouse,
Does anyone have any ideas what may be causing this? I have tried firmly pressing all my components and it still does the same thing,
Thanks
Check the ATX 20 /24 pin connector
Remove it and actually look closely at the plug and make sure none of the pins have been pushed out the back of the plug.
Sounds like a faulty hdd ide/sata or power cable, cos if windows looses connection or power to the windows drive everything will freeze up.
