Pc Games / Console Ports - Controller
Caporegime
8 Sep 2006
On Ocuk
Not sure if this is allowed as it's an emulated controller software mods remove if it is!
If anyone has a NON 360 controller and want's to set it up into a 360 one then use this software!. Just set my Saitek Rumble Force up as a 360 controller :)
https://code.google.com/p/x360ce/
https://code.google.com/p/x360ce/wiki/MainPage
Installation
Run this program from game executable directory. Game executable can look for xinput dll by different names, you can create copy of dll with name provided below till you find one that works:
  • xinput1_3.dll
  • xinput1_2.dll
  • xinput1_1.dll
  • xinput9_1_0.dll
Uninstallation
Delete x360ce.exe, x360ce.ini and all xinput dll from game executable directory.
Anyone got any other good software that does the same thing?, helpful in console ports i guess!
Alternate 360 controller windows OS drivers.
http://www.redcl0ud.com/xbcd.html#download
http://pety.me/XboxExt/
This hand util lets you turn off the wireless 360 controller without pulling the battery pack out. If your in a game you can hold the Guide button down for 5 secs to get an onscreen message about turning it off but for non GFW branded games which support the 360 controller this util works as the Guide button is copyrighted by MS so developers cannot support it outside of GFWL enabled games.
