PC Gaming Build - £1200 max
2 Dec 2015
Leicester
Hello all,
Just before I begin my forum post, I would like to say I am a new member of the forums and will try to meet all rules and etquette.
I would like a mid level gaming tower (which would also allow for some work related activites, ect) with a maximum price of £1200. I have a build below which I quite like but I would like your input, comments, criticism, etc if a part of the PC won't fit the case I have selected or is inferior for gaming.
Case: Bitfenix Pandora Micro-ATX Case (I would like if possible a small enough case to fit in a 165x435x480 mm space which the case fits with 160 h x 420 w x 465 d)
Motherboard: Gigabyte F2A88XM-D3H AMD A88X Chipset (Socket FM2+) Micro ATX Motherboard.
Processor: AMD Kaveri A10-7870K 12 Compute Core APU w/Radeon R7 HD graphics (4 CPU + 8 GPU Compute Cores)
Memory: Avexir Blitz 1.1 Original 16GB DDR3 (2.1 HMz - Dual Channel)
CPU cooler: Alpenfohn Panorama CPU cooler
SSD: Samsung 500GB 850 EVO Solid State Drive
Graphics Card: AMD R7 HD graphics.
Power supply: be quiet! pure power L8 530W power supply with 120mm silent wing fan built in.
Sound Card: Asus Xonar DX 7.1 PCI-Express Sound Card.
OS: Windows 7 Professional 64bit
Keyboard: Steelseries Apex (RAW) Gaming Keyboard
Mouse: Mars Gaming MM1 Gaming Mouse
Monitor: AOC E2460SH 24" (1920x1080) TN Widescreen Gaming LED Monitor
Its cost comes to £1,076,90 including delivery.
Could I please have your comments or critcism with this potential build.
Thanks! :)
Thank you Stulid, this may seem like a silly question but will I have to order these as parts or can I use OCUK's pc configurator tool to get the entire bundle?
Thanks again :)
OK thank you, but since I have been known to **** up several pc builds at work before, is it possible for OCUK to build and I pay a charge for it?. Becuase I don't feel confident with putting the PC together with hardware that (for me) is quite expensive to mess up with. Thanks in advance
They can and there is a fee, you would have to ask customer services specifically if they will.
I did see it rumored that its around £60 for a simple PC, so this one with GFX card etc might take you to your max budget.
I would just like to say it's probably a bad idea to squeeze a case into your opening just slightly bigger than the desktop.
It wouldn't do you any good in regards to temperatures.
