PC Gaming Build
13 May 2014
London, UK
Hi Guys,
First post here and I wanted to share my intended PC build to create a great system that i can replace with my current one :) and ask for opinions on what you guys think. What I'm able to save upon on different sites, or upgrades that are necessary. Please let me know what you guys think I would love to hear from you!!
CPU Intel Core i7-4770K 3.5GHz Quad-Core £235.99
CPU Cooler Corsair H100i 77.0 CFM Liquid £83.88
Motherboard Asus Maximus VI Hero ATX LGA1150 £151.91
Memory Corsair 16GB (2 x 8GB) DDR3-1600 £109.39
Storage Samsung 840 EVO 250GB 2.5" SSD £98.90
Video Card EVGA GeForce GTX 780 3GB Superclocked ACX £383.99
Power Supply Corsair 750W ATX12V £68.94
Optical Drive Pioneer BDR-208DBK Blu-Ray/DVD/CD Writer £65.63
Operating System Microsoft Windows 8.1 (OEM) (64-bit) £82.17
Wireless Network Adapter Asus PCE-AC68 802.11a/b/g/n/ac PCI-Express x1 £69.47
Case Fan Phanteks PH-F140SP_BK 82.1 CFM 140mm £11.98
Custom Phanteks Enthoo Pro with Window £89.99
Total: £1551.14
This is my first PC build as well :)
Look a very strong build to me! I would want to swap out the fans on the water cooler though because the ones they come with are a bit loud! Just being picky there though other than that its a good build!
Hey akilleazy thanks for the tip! that was something i did not consider! and cant wait to get started!
didn't realise you created two threads. delete the other one. anyways as I said in the other thread:
parts look ok.
but do you actually need 2 ssds? I would use one ssd and one 2TB hdd instead. also are you sure you need your optical drive? you could just download a windows 8 iso file and use your product key to install it via usb
parts look ok.
Perhaps he wants to raid them for even faster performance? Not everyone wants or needs masses of storage.
And also this should be in General Hardware, until you get your parts and start a build log, it isn't a project log thread.
parts look ok.
The two SSD's might not be necessary but the optical drive is as I have numerous games that require the cd inserted to run. If you have a solution to this I would be glad to hear it!!
Aries
with it being his first build, I wasn't sure if he needed a raid array. and I agree with you. my 1TB hdd is nearly empty
and some games you can download and then activate using your key but you'll have to double check which ones though
