PC going to pre-bios screen (power-on-self-test) on boot up
18 Aug 2011
Norfolk
Looking for some help please. Last day or so my PC hasn't been booting up properly.
- When I load up I am faced with what I believe is a "Power-on-self-test" page, similar to this: https://en.wikipedia.org/wiki/Power-on_self-test
- I press F1 to enter setup
- This takes me straight to BIOS (motherboard is PRIME X399-A)
- Then weirdly in here the boot priority's are:
  1. SSD - this only holds 5 or so VMs (no Windows installed) and nothing else
  2. DRAM - assume this is one of my RAM modules???
- It doesn't show my main hard disk where Windows 10 is installed
- I have to go to Boot Menu and manually select, at which point it either:
  1. Loads successfully (Although seems to "Default" the BIOS as SVM is disabled when I try to load a VM...(CPU Config in BIOS))
  2. Comes up with an error "blinitializelibrary failed 0xc0000017" and I have to power off to restart
Any ideas???
The hard drive is about 10 years old now but it is still loading up (eventually) - I just don't understand why it has lost its boot priority?
I'll probably format the SSD and install Win10 from a USB stick but this random error is strange.
This is what it does.
I think I have to enable fast boot.
Just putting this here now I've spent time working out how to post an image (and if fast boot doesn't work).
New battery appears to have done the trick - thanks
And a bit of dust removal at the same time :cool:
