Sad to say that my great luck has continued (never being able to run a PC for more than a couple of months before something breaks), but I'm unsure how best to rectify this.
When I start up my PC it powers up, the HDD, fans etc spin + the case light stays illuminated... this is as far as it gets. I cannot even get it to post to bios.
Previous to this I had some problems with System 32 - tried with a different harddrive and it rebooted during windows install (so it wasn't the drive) and rectified the problem by removing one of the sticks of RAM (which I assumed was faulty - either that or the motherboard slot is).
As I assumed the RAM was the problem and I ordered 2gb more of the OCZ platinum I had. I then turned off, powered down, put in the RAM and....
now, regardless of what RAM i use (new or the old one that worked) it never goes past the problem outlined above.
I'm at a loose end - I find it extremely hard to believe that the second set of RAM (or even the first following the renewed troubles) if faulty as I've tried every single stick in every slot.
I've taken the whole system apart and reseated the CPU and still no luck.
I've tried an old graphics card so I'm ruling that out.
I've reset the CMOS multiple times.
The power supply is a Corsair 650TX (month or two old) and I'm only running a stock 6300 and a 8800GTS.
Everything I've read / guessed points to the motherboard, but I can't afford to replace the motherboard only to find it isn't the problem. Similarly, the second most likely problem is the CPU.
PS. Unfortunately no one I know who has a compatible PC is willing to let me take it apart and stea
l / test parts.
Sorry for the wall of text, much appreciated as always;
Rich
l / test parts.
Rich
