pc graphics and audio problems
28 Dec 2003
staffs, uk
ok this is the first time ive ever had this problem. im trying to not only get my mic to work but if my pc is turned off or restarted one of the monitors display resolution is reset to a low res and the startbar moves to the other monitor. its as if none of the settings i use are being saved and its getting rather annoying. is there anything i can do other than a format and re-install to resolve this?
