PC hard restarting randomly
23 Dec 2013
North Wales
My PC recently has starting just randomly shutting off and restarting. Tried reverting everything to stock and it's still doing it. Temps appear normal and there is nothing in the event logger apart from it saying the PC shut down unexpectedly.
Any ideas? :(
Event log:
Temps:
Have you added any new components to your PC or have you recently installed any new software? This includes drivers. If you've installed any kind of software you could try removing it or restoring your computer to an earlier point. Alternatively it could be a virus. If you haven't already i'd suggest doing a virus scan to make sure there are no viruses on your computer. The only other thing I can think of really is a hardware failure. You could run some test on your components to see if any of them are faulty. There are so many possibilities with a problem like this so it's hard to pinpoint the exact cause.
