hi guys, pandering after your help once again!
unsure as to what is failing, although at a guess i'd say maybe the CPU?
basically, my pc had been noticeably running slower recently so i went into the BIOS and yes, the overclock had been lost and i was running at stock speeds.
so, reapplied the overclock and the voltages e.t.c (as set out in the 2500k overclock guidelines on this very forum) and restarted.
it failed to restart over and over and over.
the cpu fan was very hot to the touch so i let it cool substantially before trying again. this time it was a successful boot but windows e.t.c was very very sluggish. eventually everything ground to a halt and the PC turned itself off and began it's perpetual loop of failing to boot.
so! took the pc apart and applied some new thermal paste to the processor. rebooted and everything seemed dandy again, for a little longer than last time, but unfortunately it slowed to a crawl and turned itself off.
this is where i stand now. i'm GUESSING at a cpu failure, but obviously that's an educated stab in the dark.
any ideas guys?
my specs are:
Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
MSI (P67A-C45 (MS-7673))
8GB RAM
1TB (SAMSUNG HD103SJ ATA Device)
AMD Radeon HD 6900 Series
Windows 8.1
any ideas guys?
my specs are:
8GB RAM
Windows 8.1
