Dell Dimension 4550
During a thunder storm last night with lots of lightening the pc just suddenly switched off. It won't power up again. Nothing happens when I press the power on button. The PC was connected to an 8 socket surgemaster extension lead. All the other devices on the extension lead (phone, monitor, broadband modem) _appear_ to be fine. Monitor switches on/off OK.
I changed the fuse in the plug. When the hardrive is connected to the mains a light does go on inside the hardrive so power is getting into the box.
Can anyone please advise what components I need to check in the PC and
an you tell me what test procedure I should use to try and get to the bottom of the problem.
Thanks a lot.
Thanks a lot.
we're taking a look at this.
