Seems to be a spate of PC issues with me at the moment.
I'm hoping this one is a simple fix
Basically, i'd just left my PC on upstairs, went downstairs for a bit for some lunch.
Came back up to find that the screen was black, the PC power light was on though, and the monitor is functioning correctly.
I have a mouse that lights up when it's on, and that had no light. Indicator of some kind of fault with the motherboard or something?
I turned everything off at the mains after that, disconnect the power cable for a bit, and left it to for a while.
Connected it all back up, attempted to power it up and the same thing happened. One beep as normal, but then no activity on the monitor, no power light on the mouse and no further activity by the looks of things on the PC.
What does this indicate please?
Simple fix or do i need a few new components?
My system is...
Windows 7 64-bit
Q9550 quad core - not overclocked.
ASUS P5E
Sapphire Vapor 5770
4GB Ram (can't remember specifics)
500 Watt Antec Neo PSU
WD 180GB HD (this is pretty old, about 6 years i think, has my Windows install on it.)
WD 750GB HD (this is holding my music etc)
All got the latest drivers etc, besides the BIOS, which after a few upgrades i left it well alone.
I'm pretty broke at the moment, so I hope it's something simple
My system is...
Windows 7 64-bit
ASUS P5E
Sapphire Vapor 5770
