PC has died
9 Jul 2013
Hey guys,
For the last week or so, my PC has been turning off, and refusing to power on, It would power after a few attempts. Today, the PC turned off and won't power on at all, no lights noise etc. I have taken everything out and put back in, wires too.
The only thing out of place is the CMOS battery. It's attached via a red and black wire to the motherboard. The black wire has snapped / come out of the socket.
The PSU is only a couple of weeks old, (from overclockers)
Can this battery stop a boot, or is there something more sinister going on?
Thanks for your help
MSI FM2 A75IA E53 (from Old Build)
Silverstone 600w Bronze (New)
AMD A10 APU (from Old Build)
HD7870 IceQ (From Old Build
8 gig RAM (New)
Bitfenix Prodigy (New / B-Grade)
All from OCUK
my first thought if your saying there is no power would be to check the PSU, could you check it with another one?
I don't have another. Because it's very new and half decent, I assumed it would be ok. Is there a easy way of testing the PSU to see if its broken, If it is, will OC replace it? Thanks for your help:)
This is the bit I'd be concerned about and can't be helping
I have re-attached the wire to the battery, but still no power up. Has it killed the motherboard :confused:
Having no battery shouldn't prevent the computer from booting. The fact that the wire is damaged might though. I'd try without the battery in and see if there's a difference.
Your'e only right! Spot on mate, thank you very much. I guess I need to order a new battery and cable from somewhere :)
