PC has no sound
11 Sep 2008
I have a new problem. Apparently i have no audio devices in my PC, and i have no sound at all. When i go to the sound volume, i click on it, and it says "There is a problem with the driver for ATI High Definition Audio" Any ideas what i need to do? WHen i click apply fix, it fails (As always with Windows, the repair tool never works)
Cheers
download the ATi catalyst driver pack - that has the HD audio drivers as well as the GPU drivers - if that doesn't work then you probably have a fault on the card somewhere.
good luck :)
