PC/HDTV issue
9 Apr 2004
Central Scotland, UK
mods: sorry if this is in the wrong section, i had a look through them all but couldnt decide where it was best suited!...
thought id post this up see if anyone has any ideas, im leaning towards calling LG to get an engineer out but see what you guys think.....
Ive got a 42" LG LED LCD tv, with an HTPC connected to it along with a blue ray player and X360 (all 3 devices are connected via HDMI)
the HTPC suddenly stopped displaying anything, when i select the input menu on the TV it recognises something is connected to that port but when i select it, it gives me a no signal message.
straight away i tried using a different HDMI port, no luck.
different HDMI cable, no luck
Tried xbox and blue ray on the port that the Pc is usually on, they worked fine
assumed the graphics card was dodgey so ordered a new one (i dont game so just run cheapo radeon HD6450, so wasnt too expensive), no luck!!!
tried my new and old graphics card on different PC's they work fine
lost the rag, took my PC to my mates house and tried it on his TV and it works fine.
do PC's and other devices use HDMI differently? i cant understand how HDMI devices are working fine on my TV and my PC is working fine on another TV yet the 2 of them suddenly wont work together?
ive tried reseting the TV and updating the software on it, still no luck.
That's a perplexing one :( The only thing I can think of is something software related on the HTPC that is causing an issue with that particular combination. I can't imagine what though. Did you clean off all the old drivers (using Driver-Cleaner or some such) before installing the new video card? Installed anything else on the HTPC recently?
