- 22 Aug 2003
Hi Guys currently having a big problem with my PC
Using the MSI Z77A-GD80 w/Thunderbolt Intel Z77 with I5 CPU
bought it new from here June 2012
here goes
2 nights ago it just shut down completly rather like the power had gone off
but it was not the mains power at fault
rather baffled as to what has happened took the side case off and tried to boot it up the case fan and CPU spin for about half a second then it just shuts down again
a couple of lights on the motherboard come on for those split seconds
at first I thought it might be the power supply so I disconnected everything bar the boot drive and it is still the same
money is extremly tight as I have been made redundant and cant afford to buy a new Power supply only to find out it is something else and the same with buying a new motherboard
how long is the warranty on top line MSI Motherboards 12 months no doubt
but as things stand not sure where to look first just dont want to spend a ton of money on bits that might not be needed
wonder if an email to MSI might help
thanks and would really appreciate any info at all that might find out what has happened
windows 7
8gb ram
400wtt PSU which has worked flawless for 2 years since I bought it here from new
and the lights and every thing at least try to come on when I press the start button but within second it just shuts down no post to bios or anything
here goes
windows 7
8gb ram
