Yes! They are both DDR3 and the ram is standard 1333mhz. Just a quick question are/or will you be using a 64bit operating system? if not don't bother with 8gb of ram, as you can only use up to 4gb of ram with a 32bit OS. Just a heads up.
Why not go for this ram instead save yourself a few ££s. http://www.overclockers.co.uk/showproduct.php?prodid=MY-118-GL&groupid=701&catid=8&subcat=1516
