Pc help
9 May 2007
Hi so I just had a move of rooms and when I go to plug my pc in it wont come on what could it be. I have also checked if all the cables are still plugged in and they are.
Specs
i5 3570k
Gigabyte GA-Z77X-UP4
16gb Samsung green
his hq 7950
ax1200
corsair 800d
Have you tried using some other plug in the socket? (could be a loose wire/fault on the socket side)
