PC in perpetual boot loop
6 Oct 2012
(do-or-die) Wye, Ashford, Kent, UK.
hi all,
ok, as the title thread mentioned, i'm stuck in a boot loop with my pc.
i have attempted to scour the realm of google to help me trouble shoot/diagnose this issue., so here goes:
by the way, this is new to me, i've never encountered this before. i don't even know if this is the correct forum area :(
i was restating the pc after trying to get a game via steam to recognize d3doverider for its vsync purposes.
i restarted, and that's where the boot loop began.
i unplugged all usb peripherals apart from the keyboard and my lcd tv.
no change.
i tried booting in safe mode.
no change
last known configuration
the same problem
i found my original os install disc, pooped it in and i'm assuming that it should automatically go to language settings with options to "repair disc", but i don't see that.
is there something i'm missing?
i repeatedly tap f8 to get to the advanced options, but i don't see an option to repair the disc.
can you guys advise?
Mobo: Gigabyte H61MA-D3V Socket 1155
GPU: Nvidia GTX 460
CPU: i3 2100
RAM: 4gb
PSU: evo labs 750watts
Everytime i have seen this it has meant a complete reinstall of Windows!! System is corrupted
Or possibly the hard drive has went kaput. I've had those exact same symptoms. So many sectors and blocks was non writable, slow death. Boot repair loop until I changed the drive.
I've had this recently. Took the mobo out the case and it fired up first time. Must've been dust causing a short circuit or something.
Maybe worth a try before you write off components?
@ koolpc:
i have my vista 32 installation disc. how do i use it to try and re-install?
i and placed it in the drive, but i don't see any option on the 'recovery screen' to access it.
all that is on the screen is safe boot mode, last known configuration etc
@ V F:
my friend told me it could be a virus on the hdd. or it is just dying/dead.
i have heard that i can get an external sata desktop enclosure for it, so i can plug it in to the back of my mac. then (hopefully) i can transfer the files onto a waiting dvd-r.
i have no wish to transfer the files directly to the mac desktop if something is corrupted.
i could download avast (if it is available for a ppc mac) and scan it when i plug the enclosure in the back of the mac?
Not at all.
Could be.
Best thing to do is get hold of a Hiren CD/DVD and boot to that.
Use the tools there to test the hard drive and if that is healthy boot into MiniPE (windows) and run check disk on your drive (CHKDSK "drive letter" /F)
@FBI7:
you removed the mobo?
so you removed it, as in just had it resting outside the cracked case on a flat surface etc?
Yup, took the mobo out the case and placed it on a non-conductive surface. I only plugged in the bare essentials: 1 x gfx card, ram, 1 x hard drive and hooked up the psu. Then I briefly shorted the two pins on the mobo that the power switch plugs into and she burst into life.
cheers swordfish, i'll get on that!
urghh!
burst into life and not flames?
heh, the mention of 'shorting pins' scares the stuffing out of me :)
@ koolpc:
Go into the bios (Usually by pressing 'Delete' or 'F2' at start up) and select DVD as boot drive and save.
Restart PC and press enter when it asks to boot from DVD.
Follow on screen prompts. Do a full clean of drive (Dont select upgrade) and then install OS onto it.
Let us know how you get on
You will lose all stuff on HD so if you can find an enclosure for it you might be able to extract all files off of it if you have another pc to transfer to.
I dont think it is a hard drive failure. I think it is a corrupted HD.
if i go the route of trying out the hiren cd, that way i should find out if the hdd is corrupted (or not).
if it is corrupted, i'll get another one :(
do i need to buy an enclosure, or can i plug the old pc hdd into the back of the new hdd when i install it?.
is this is what is termed "slaving"?
a friend told me i can do that instead?
No. You can't do that.
You would need another PC to connect the hd to either in an enclosure or direct to PC.
Best thing to do is get hold of a Hiren CD/DVD and boot to that./F)
i've never done this before.
i've burned the iso's for the Hiren and MiniPE discs.
how do i boot the hiren disc?
will i need to do the above?
Yes.
Put the Hiren Boot DVD into the DVD tray and restart the PC. Press the appropriate key to enter the boot menu (probably D8,F11 ro F12 or ESC).
Depending on the version you have you want to navigate to the Dos Tools Menue and then to Hard Disc Testing. Select Seatools (as this will test other drives). Select yoru drive and run a long test on it.
Once the drive test has finished and assuming the drive is healthy repeat the taks above but select Windows XP Mini PE from the options list and let Windows load. Once Windows has loaded run a command prompt (there will be a shortcut or click start, run, and enter CMD). Once you have the command propmt up you need to enter the following (without the quotes) "CHKDSK <drive letter>: /F
Let the check run through and do this for all the drives you have.
i got into the gigabyte bios menu.
i selected the dvd drive as the priority
i selected the hdd secondary to that , saved, restarted.
the hiren cd booted up, chose seatools.
it started testing, then told me that there was no hdd installed?
OK. I beleive that is because your drive is set to ACHI mode. Happens sometimes. Go into the BIOS and change it to ATA/IDE (either works) and reboot doing the same thing with the Hiren and launch Seatools then. Your drive will now be visible.
One thing make sure once you have doen your testing that you switch it back to ACHI.
i checked under the 'peripherals' tab, found 'SATA mode selection', IDE was already selected.
