Assuming your router doesn't have a reserved range and or the ability to give a specific IP to MAC address, than just assign your computer a .254 IP address for the last octet.
Start, run, cmd. Type in ipconfig/all. Then go into control panel, network connections, local area connection, properties, TCP/IP, enter your static IP in here, and then get the rest of the info from ipconfig.
