PC is bluescreening every 12 hours or so
18 Oct 2009
Wakefield
I has been BSOD for a while but i cannot figure out what the problem is, i know its a hardware problem but there is no error codes because windows 8 no longer uses the traditional BSOD log it just had a simple there was a problem message.
Operating System: Windows 8 Pro
Ram: 16gb Corsair Vengence (used to do it on my old ram too)
Cpu: i7 2600k no overclock
gpu: gtx 580
psu: 1000w Corsair
MB: Asus p8p67 Pro
Vccio is currently auto and at 1.056 atm I will high and try it
Everything is on auto atm
CPU volatage is hovering around 1.08 atm
i cudnt find XMP setting option so im not sure but i will try it with the 1.08 volt for vccio and see how it goes
Maybe try the BSOD section on windows 8 forums they can walk you through testing routines to narrow down the fault. I had a problem with windows 7 and used the windows 7 forums to fix mine.
This is one from yesterday
Code:
Dump File         : 120912-21593-01.dmp
Crash Time        : 09/12/2012 20:07:25
Bug Check String  :
Bug Check Code    : 0x00000124
Parameter 1       : 00000000`00000000
Parameter 2       : fffffa80`0f70b028
Parameter 3       : 00000000`be200000
Parameter 4       : 00000000`0005110a
Caused By Driver  : hal.dll
Caused By Address : hal.dll+2d965
File Description  :
Product Name      :
Company           :
File Version      :
Processor         : x64
Crash Address     : ntoskrnl.exe+7a740
Stack Address 1   :
Stack Address 2   :
Stack Address 3   :
Computer Name     :
Full Path         : C:\WINDOWS\Minidump\120912-21593-01.dmp
Processors Count  : 8
Major Version     : 15
Minor Version     : 9200
Dump File Size    : 301,840
Here is one i got 2 days ago
Code:
Dump File         : 120812-33390-01.dmp
Crash Time        : 08/12/2012 20:38:35
Bug Check String  : PAGE_FAULT_IN_NONPAGED_AREA
Bug Check Code    : 0x00000050
Parameter 1       : fffff6fb`40000000
Parameter 2       : 00000000`00000000
Parameter 3       : 00000000`00000000
Parameter 4       : 00000000`00000006
Caused By Driver  : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+7a740
File Description  :
Product Name      :
Company           :
File Version      :
Processor         : x64
Stack Address 1   :
Stack Address 2   :
Stack Address 3   :
Computer Name     :
Full Path         : C:\WINDOWS\Minidump\120812-33390-01.dmp
Major Version     : 15
Dump File Size    : 301,896
First could be not enough voltage to CPU or not high enough VTT voltage.
2nd is usually RAM related, so I would say bump up the VTT voltage some more (Sounds like its VCCIO on your board)
think i managed to fix the first 2 errors as i havent had them since but now i get a memory management blue screen 5+ times everyday.
Code:
Dump File         : 121512-26562-01.dmp
Crash Time        : 15/12/2012 11:23:03
Bug Check String  : MEMORY_MANAGEMENT
Bug Check Code    : 0x0000001a
Parameter 1       : 00000000`00041793
Parameter 2       : fffff680`0004b668
Parameter 3       : 00000000`00000002
Parameter 4       : 00000000`00000001
Caused By Address : ntoskrnl.exe+7b340
File Description  :
Product Name      :
Company           :
File Version      :
Processor         : x64
Crash Address     : ntoskrnl.exe+7b340
Stack Address 1   :
Stack Address 2   :
Stack Address 3   :
Computer Name     :
Full Path         : C:\WINDOWS\Minidump\121512-26562-01.dmp
Major Version     : 15
Dump File Size    : 301,880
