PC is extremely loud and need help with the noise.
10 Sep 2013
READ EDIT: Has some key information and I will list it: The sound seemed to magically have decreased without doing anything or removing any processes. I want you guys to help me better cool my computer so I was thinking of getting a CPU heatsink called Cooler Master Hyper 212 EVO (120mm).
Hey, my PC is extremely loud, I literally cannot hear anything apart from this very noisy PC. I just cleaned the PC and I have lowered the temperature by 10 degrees Celsius however the sound from before the cleaning is still being a annoyance. I was thinking of getting new fans however I am clueless and I have no idea what to do, here is the PC specs, just tell me what to do.
CPU: AMD FX-6350 3.9GHz 6-Core Processor
MOBO: Asus M5A97 LE R2.0 ATX AM3+ Motherboard
RAM: Corsair Vengeance 8GB (2 x 4GB) DDR3-1866 Memory
HDD: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
GPU: XFX HD 7970 DD Edition 3GB GDDR5 DVI HDMI Dual Mini DisplayPort PCI-E Graphics Card
PSU: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply
CASE: Zalman Z9 Midi Tower Case
I do not know where the source of this however I can assume its the fans and I want to upgrade them or whatever, I am clueless and have no idea on how to cool my computer, all I know is basic PC components and that's pretty much it. I was thinking of getting this
EDIT: Thanks for the help, PC is still loud and confused on what to do.
Is it only noisy under load, or all the time?
Install SpeedFan: http://www.almico.com/sfdownload.php
That will tell you the temperatures of the various components and also the speed that your fans are running at. It would be good to isolate the problem to either your case fans, GPU or CPU.
http://prntscr.com/5jvlnc
Here are the results for Speed Fan, I don't know what most of this stuff are however this may be useful. If you need a screenshot on every window then I can do it for you.
What case are you currently using?
One option is to check to see were the fans are plugged in and look at a fan speed controller which can fit in one of the drives bays.
My case is Zalman Z9 Midi Tower Case, also I don't know what a fan speed controller is however I can link you a screen shot I made on Speedfan, also I want to mention that my PC has been more quieter however I think it is still best if I upgrade my cooling just in case.
just go into bios and turn them down, no?
I could but I am worried if my components may be damage if it doesn't receive much cooling. My PC has been more quieter since I posted this thread but I would like help with installing new fans and improve cooling just for the long run.
Bump: Read the edit at the end of the first post. My PC seemed to go quieter however for some reason afte a while it's loud as usual. My AI Suite told me that the CPU temperature has raised to 65 degrees Celsius.
I've also noticed that the CPU fan was the source of the loud noise. As I mentioned above the AI Suite notified me that the CPU Temperature has risen over 75 degrees Celsius.
I added the case to the thread, just in case it's here, Zalman Z9 Midi Tower Case.
Shivy011, the name of the case is Zalman Z9 Midi Tower Case, the CPU heatsink is the one that came with the core itself, which I assume is the AMD Stock Cooler.
I am not experienced with cooling and stuff however the case name will probably give you an idea. Also, just in case, I have used this PC without any problems for the past one year. I never upgraded anything inside the PC until now where I am thinking of getting a new heatsink.
Here are the links to the images you requested, the images showcase each fan whilst the PC is off, I don't know what molex is or the 3 pin connection, etc. however these could help solving the problems.
http://imgur.com/a/af8jJ
(Imgur albun)
nkata, case is Zalman Z9 Midi Tower Case, don't know the case fans but the case name will most likely solve the question. I did set up the heatsink properly. I think the fans are PWM type but let me know how I can check it.
Edit: I am going to wait for about 10 minutes and then take screenshots, my antivirus is just being slow and needs some time.
Edit 2: I uploaded the images of each fan, I also cleaned everything for about an hour and taking the pictures. I hope this helps, also I heard a decrease of volume but I don't think you should trust this since I just turned it on and after an hour I will tell you the noise level.
My PC has been very silent lately, I think it's due to cleaning the stock cooler, also Shivy011, the case fans are connected to something like this http://imgur.com/a/af8jJ.
The image is not mine but I found it on google, however it is connected to one of those. They are connect straight to the PSU. I am thinking of getting the BeQuiet thing cooler, I forgot the name. I don't know much about cooling but will this fit on my CPU? If yes then I will order it :) Thanks!
EDIT: The reviews say that the cooler is good however I don't know how I should mount this gigantic thing onto my CPU and how I am supposed to assemble these together. Do all stock fans come with this and is it compatible with my CPU/Case?
Woops, sorry about that I accidently linked my album that I used earlier in the thread. Here is the image I was meant to show you. http://i.imgur.com/EXJvd.jpg
Edit: Does the manual inside the box show how to assemble the cooler because I've never tried this before and also will I have to repaste the cpu? I am not too confident with repasting things so yeah.
Is it ok if I just get a CPU cooler, I think my stock fans are quite ok and will get some in the future if I need any. So currently all I need is the beQuiet cpu cooler and then I just need to assemble it and mount it on the cpu?
Update, the PC has been extremely quiet, I don't think I will be getting the bequiet cpu cooler any time soon. The problem was just that the CPU wasn't clean and was infested with dust. After I removed the dust, I haven't heard a single thing or no errors on high CPU temperatures. In the next 4 months I might order a CPU cooler however currently I don't need it. Thanks guys, I will close the thread now!
