- 10 Feb 2011
Hi all. First thing first is thank you to you all for trying to fix my PC. In the end I sent it out to be fixed and told them what was wrong with the blue screen 116 code, crashing and slow down in games. It turned out to be the graphic card dead all this time for last 3 years as HDMI to HDMI never worked. I got the Asus 970 GTX 4GB version and first thing I did was try the HDMI to HDMI and it worked straight away using same TV. Games run fine and no slowdown apart from odd time due to Vsync I think. The only thing is that the PC takes 1 minute 24nds to boot which stays on the gigabyte logo. then normal 4 ring boot up which takes a 2nd and don't spin all the way round as it did be for. I tried going into bios but it locks my keyboard out so cant.
Also they put Razer Cortex on but I have to sign up and just wanted to no if it was worth it?.
Thanks.
Thanks.
