As in the subject header. My PC keeps downpowering and rebooting itself after 10-40 minutes. So it sometimes crashes instantly, reboots on it's own, Windows loads. Other times it crashes and I must hold down the power button to turn it off and on again. It looks like it may be getting stuck when trying to recycle after the crash occurs. The Motherboard light is still lit up, I can hear the fans or something else drawing power but the system appears dead. GPU lights, mouse, keyboard etc don't power on when this happens.
I have no idea what the issue is. I tried running the software based run commands like chkdsk r, sfc scannow, DISM with no problems reported. Ran some cleaner software, did disk cleanup, did a system restore to a day or two earlier prior to the crashes. Yet it still randomly reboots. No recent app software installation changes either, so it has to be a problem with the hardware. I also ran some health checks on the WD Blue SN550's through the WD Dashboard and that reports nothing either. I also had MSI Afterburner and HW Monitor running and I see no obvious spikes in temps + usage, everything appears to be normal. That being said I don't understand the wattages and what not. The only change I have made in the BIOS is re-enabling XMP Profile1 after every bios flash. Everything is upto date when it comes to windows updates, bios, chipset from AMD website, audio, network etc with most of these updates being done a couple of months ago. The crashes / automatic reboots began happening a few days ago. All of these system reboots have occurred when idle or when browsing.
The only thing I have noticed is the chasse where my PSU is located seems to be making a popping noise upon every boot-up and continues making the same noise every 10 or 20 seconds. I can't say I have noticed this sound before until recently. It sounds like the sort of noise you would hear when a water cooler is pumping water or is on the verge of death and makes a faint noise. I can't be sure if that is the issue or not though, not the best person to ask when dealing with computers.
Current system specs
OS: Windows 10
GPU: Gigabyte Aorus 1080ti (purchased in 2017)
Display: MSI Optix MAG274QRF-od 27 inch 2560x1440p 165hz (purchased in 2022)
CPU: AMD Ryzen 9 5900x 12 core processor (purchased in 2021)
MOBO: MSI MAG B550 Tomahawk (purchased in 2021)
RAM: Team Group 32gb DDR4 2X16 (purchased in 2021)
Cooler: Alpenfohn Brocken 3 (purchased in 2021)
PSU: EVGA SuperNova G2 1000W (purchased in 2015)
Case: Lancool II Mesh Performance (purchased in 2021)
NVMe: WD Blue SN550 1TB installed on Windows 10. Secondary WD Blue SN550 installed too (purchased in 2021)
SSD: Samsung Evo 850 1TB
I have no idea how to identify the actual issue. I have no other spare parts and no secondary system to test things on. Even if I did I would still be woefully out of my depth. I even botched my Windows install a while back selecting CSM Legacy instead of UEFI because I couldn't find a selectable boot drive. I just don't have a clue.
If a part or two needs replacing what would be the best upgrade path? I mainly just browse and watch / listen to content but I do buy some of the latest gaming titles from time to time. Those storage drives for example are terrible when downloading or patching STEAM games. The download speeds continually fluctuate or halts the download process the second the disk usage hits 100%, happens almost every single time I download any large file through STEAM.
If it turns out to be the PSU or GPU at fault i will be forced into yet more replacements due to more dead hardware. I don't know what the standard warranty for purchases made through Overclockers is but if it's 2 years or more I might be able to RMA the purchases made in 2021 back to Overclockers.
So I may need a PSU or GPU replacement being specced for the system above.
OS: Windows 10
