So here are my specs:
Arctic Cooler Freezer 13 CPU Fan
Hydra case
2 Extra 140mm Fans (which run at a constant speed I believe, because they're plugged into a PWR slot not a fan power slot?)
Temps are fine, CPU reaches 60 max on full load. The problem is, my PC is SO LOUD. I can't even figure out if it's the CPU or not, since even if I go into the BIOS and change the CPU Smart Fan Control to manual (0.75/1c - lowest setting), it still seems to sound just as loud.
What have I done wrong? Reading my CPU cooler reviews, people say it's barely noticeable, so maybe it's not that, maybe it's the 140mm fans? Or maybe its my HD? I don't know!!
I also bought a fan controller but have yet to be able to install it, I can't remember exactly what the problem was, but it was something to do with having so many molex connectors, not enough power connections on my motherboard or something.
Anyone help? I want a quiet PC, not a jet engine.
Please do not try to circumvent the forum filters, and I suggest reading the FAQ for the rules.
- i5 2500k @ 4.4ghz (Arctic Silver Thermal Compound)
- ATI Radeon HD 7850 2GB
- Gigabyte Z68a-g3-b3 Motherboard
- 8gb Corsair Vengeance DDR3
- 600W Corsair Builder Series 600CX V2 80PLUS Power Supply
- Samsung SpinPoint T 320GB SATA-II 16MB Cache HD
Hydra case
In future, find the products on OcUK and link those as mentioning competitors is against forum rules and doesn't go down too well.
or remove them.
