Hello,
I built a new PC a few months ago, but for the last month or so i have been having intermittent faults.. Though to be honest i was away just after the build so not really bedded in for a while.
I will provide a description of the fault, and then give then machine specs..
The power on button on my case has stopped working, pressing the on button on the motherboard does not work either. If a flick the on off switch on the back of the machine a few times the machine will power correctly. Once the machine is on it is stable and does not crash. However then sometimes it will power with only one of the two graphics cards working. i cannot seem to find the issue, and i don't want to go buying parts to exchange out without an idea of what the issue is..
Things i have tried:
So any thoughts?
The spec of machine is as follows:
- Checks case connectors to motherboard
- Turned off each graphic cards to test them they work independently.
- check power connectors and swap them around to other free slots on back of power supply
So any thoughts?
- Asus Z87 MAXIMUS VI HERO Intel Z87 (Socket 1150) DDR3 ATX Motherboard
- Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor & Corsair H100i CPU Cooler Bundle
- Kingston HyperX Beast 16GB (2x8GB) PC3-19200C11 2400MHz Dual Channel Kit (KHX24C11T3K2/16X)
- MSI HD 7970 OC 3072MB GDDR5 PCI-Express Graphics Card*
- Sapphire HD 7970 OC BOOST 3072MB GDDR5 PCI-Express Graphics Card
- Seasonic X-Series 1050w '80 Plus Gold' Modular Power Supply
- Corsair Obsidian 800D Full Tower Case - Black
