Hi everyone,
This is my first post here so I am not 100% sure if this is the correct place to post this. If not, I apologise.
I've had my PC for around 5-6 months now and unfortunately it has started having issues.
Here is a list of the issues:
It has been happening more and more frequently lately so I am getting worried that some part of the hardware is failing... Which would be bad as all the parts are high-end and expensive.
Here are my specs:
Note: I originally thought that the overclocking may have been the issue so I removed it and set everything back to the base settings/config, but the problems still occurs.
Does anyone have any advice or am I best paying to get a PC specialist to give it a complete check over? (I fear this may be expensive)
Thanks you in advance!
- One motherboard sensor is constantly showing as 128 degrees
- On start up 6/10 times the PC will not load correctly so my monitors, keyboard, mouse etc are not powered. Meaning I have to restart the PC using the restart button on the case.
- On start up 7/10 times my PC will show a "Power Surge On Hub Port" error message and all my USB devices will restart (mouse, keyboard, webcam and speakers)
- The CPU usage regularly exceeds 80%-90% when playing even the most basic games or even just watching streams on Twitch.tv
- The PC will randomly crash and require restarting or completely shutting down. (No error messages are shown, it just freezes and/or shuts down)
Here are my specs:
- CASE: Corsair Carbide 540
- PSU: EVGA SuperNova G2 1300W - Gold Rated
- COOLING: Custom built water loop
- CPU: i7-4770K o/c'd to 4.6GHz
- MOBO: Gigabyte G1.Sniper 5 Intel Z87
- RAM: Avexir Venom Series 2133MHz (16GB)
- GPU: 2x EVGA 780Ti Superclock with EK Water Blocks
- SSD: Samsung 1TB SSD 840 EVO
- HDD: 2TB Seagate SSHD
