PC Keeps rebooting
6 Sep 2005
I turn on, everything loads, start using and within 10 mins the computer just restarts. In bios, it never turns off.
I run Win XP Pro. Temps are CPU 30-33 and GPU 28-30. Ambient upto 48
Any ideas. Thanks :confused:
Full spec-
Tyan K8WE
2 x Opteron 244CG (800mhz 1.8)
4 x OCZ PC3200 ECC REG RAM (2gb per CPU) (200mhz 3-3-3-8)
2 x XFX 7800GT SLI
2 x Maxtor Atlas 15KII 68p SCSI
2 x Maxtor 200gb SATA
1 x Plextor 716 SATA DVD
Enermax Noisetaker 600w PSU
Linksys 54g wireless PCI card in PCI-X100 slot
CPU's & GPU's are liquid cooled.
I swap components often and have had to fully install Windows/Linux several times in the last six months, but it never 'just turned off' before.
Only mild overclocking (1.8 to 2.05 on CPU) and bios unlocking of the SLI to full bandwidth
Mainly happening in Windows?
if so:
Right click My Computer -> Properties -> Advanced -> Startup Options -> UNcheck "Automatically Restart in case of BSOD"
Then when it would have rebooted, it will give you an error instead, which you can fire into google.
If it's just randomly 'turning off' then got another PSU to try?
