This is driving me crazy now!
Randomly the computer keeps restarting, never under load or playing games as intensive tasks are never carried out on this computer.
I have ran memtest and prime95 and the temps are good and the ram is fine.
The spec of the computer is:
OCZ Vertex 2E 60GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE60G)
AMD Phenom II X4 Quad Core 840 "95W Edition" 3.20GHz (Socket AM3)
Asus M4A88T-M AMD 880G (Socket AM3) PCI-Express DDR3 Motherboard BeQuiet Pure Power L7 530W Power Supply
OCZ Platinum 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Ultra Low Voltage Dual Channel Kit (OCZ3P1600C9ELV4GK)
Please see below readout from hwmonitor.
Are the voltages ok?
CPUID HWMonitor Report
Binaries
HWMonitor version 1.1.8.0
Monitoring
Mainboard Model M4A88T-M (0x00000200 - 0x00A975F4)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8712
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8712
LPCIO Revision ID 0x8
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 12 08 00 00 C1 A0 00 00 80 01 00 1F 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 02 90 02 30 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor ITE IT87
Voltage 0 1.04 Volts [0x41] (CPU VCORE)
Voltage 2 3.39 Volts [0xD4] (+3.3V)
Voltage 4 12.74 Volts [0xC7] (+12V)
Voltage 5 -6.21 Volts [0x61] (-12V)
Voltage 6 -14.27 Volts [0xDF] (-5V)
Voltage 8 3.31 Volts [0xCF] (VBAT)
Temperature 0 29°C (84°F) [0x1D] (TMPIN0)
Temperature 1 34°C (93°F) [0x22] (TMPIN1)
Fan 0 2344 RPM [0x120] (FANIN0)
Fan 2 675000 RPM [0x1] (FANIN2)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
00 19 00 FF 03 37 FF 07 37 FF 07 40 39 07 20 FF 04
10 FF FF FF 77 D0 80 81 80 01 FF 00 FF FF FF FF FF
20 41 FF D4 FF C7 61 DF FF CF 1D 22 80 DD F3 F3 F3
30 FF FF FF FD FF FF FF FF FF FF FF FF FF F7 FF FF
40 FF FF FF FF FF FF FF FF 2D FF FF FF FF FF FF FF
50 35 18 7F 7F 7F 00 56 56 90 56 F9 12 80 00 00 00
60 00 19 37 35 93 00 FF FF 00 19 37 35 93 02 FF FF
70 00 19 37 35 93 7F FF FF FF FF FF FF FF FF FF FF
80 00 00 00 00 FF FF FF FF 00 00 FF C0 02 00 99 99
90 7F 7F 7F 00 00 7F FF FF 7F 7F 7F 00 00 7F FF FF
A0 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
-- Core 2
-- Thread 0 2
-- Core 3
-- Thread 0 3
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name AMD Phenom II X4 840
Codename Propus
Specification AMD Phenom(tm) II X4 840 Processor
Package Socket AM3 (938)
CPUID F.5.3
Extended CPUID 10.5
Brand ID 17
Core Stepping BL-C3
Technology 45 nm
TDP Limit 95 Watts
Core Speed 803.7 MHz
Multiplier x FSB 4.0 x 200.9 MHz
HT Link speed 2009.2 MHz
Stock frequency 3200 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
L1 Data cache 4 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 4 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
FID range 4.0x - 16.0x
Max VID 1.400 V
P-State FID 0x10 - VID 0x0C - IDD 19 (16.00x - 1.400 V)
P-State FID 0x9 - VID 0x14 - IDD 15 (12.50x - 1.300 V)
P-State FID 0x3 - VID 0x1A - IDD 13 (9.50x - 1.225 V)
P-State FID 0x100 - VID 0x28 - IDD 8 (4.00x - 1.050 V)
Package Type 0x1
Model 40
String 1 0x4
String 2 0x6
Page 0x0
CmpCap 4
ApicIdCoreSize 4
TDC Limit 76 Amps
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Attached device PCI device at bus 0, device 24, function 4
Binaries
Monitoring
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8712
Config Mode LDN 0x4
Hardware Monitors
Processors
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
-- Core 2
-- Thread 0 2
-- Core 3
-- Thread 0 3
Processor 1 ID = 0
Codename Propus
CPUID F.5.3
Extended CPUID 10.5
Brand ID 17
Core Stepping BL-C3
Technology 45 nm
TDP Limit 95 Watts
FID/VID Control yes
Max VID 1.400 V
Package Type 0x1
Model 40
String 1 0x4
String 2 0x6
Page 0x0
CmpCap 4
ApicIdCoreSize 4
TDC Limit 76 Amps
