Weird problem really. Haven't installed anything for about 2 days. Just browsing websites and then all of a sudden my whole pc locks up. Nothing that strange all though it hasn't done that for about 2 months or so. After about 5 seconds it comes back and everything is moving again. So i close all the websites and programs down and restart the pc thinking the problem will solve itself. Load back up and still the problem persists. Lock ups every minute and then they get more and more frequent.
I go into safe mode and see if the problem still persists and unfortunately it does. I've ran a virus scan and hijack this and everything is fine. Straight after the first lock up I can't load any programs at all. I can only use the one that was open at the time.
I've realised the CPU goes right up to 100% when this lock occurs. Could it be a dodgy ram slot or something? Theres no .exe using more than your average percentage in the processors lists.
Anyone know any suggestions/solutions? I've done a quick google search but the problems are not as specific as this.
Ran a temperate check just then as well and everything is fine. Removed my USB hard drive too to make sure but still seems to be doing it.
I haven't formatted for about 2 years which would almost definitely solve the problem but I don't really want to format it right now.
Specifications:
Windows XP 32 SP2
AMD 3800+
2gig RAM
Specifications:
Windows XP 32 SP2
AMD 3800+
2gig RAM
I'm going to try and fix this using the XP CD anyway
