- 8 Oct 2014
- Here somewhere!!!
Hi all,
I was just wanting to know if any of you guys, when cleaning your rigs inside from dust ever check the capacitors for signs of wear? I've just cleaned mine and I can see that one of the capacitors on my motherboard next to the 4 pin power connection is showing signs of wear (discoloured) but not yet leaking.
I have got a new one to replace it, so has anyone else ever changed one? and if so did you have any issues afterwards?
