PC mild revamp
8 Mar 2014
Hi
Thought this would be a good place to ask about the following bundle in case anyone has this config.
http://www.overclockers.co.uk/showproduct.php?prodid=BU-007-OG&groupid=43&catid=2512
Looking at putting this bundle together but replacing the cooler with a Noctua NH-U14S OR NH-U12S. Will either cooler fit with that RAM or will I lose a slot? Worried too that it might cover the PCIx16 slot partially too :(
Currently I have a corsair 520w PSU with a E6600 but would this PSU be beefy enuff to handle the linked bundle along with 3 raptor drives, 1 sdd & a 550Ti?
Probably the only static things that I'd not be keen on swapping out on would be the i7 4770K and the fans so open to other RAM/mobo recommendations.
Budget is around £650-700 mark
Any pointers appreciated :)
Link works fine, get better browsers:p
The Noctua NH-U12S has 100% ram compatibility on that board.
The 14cm version may interfere with the top 16X slot, the 12cm will be fine.
