PC Monitor Needs Help!!!
10 Jan 2011
Hello Guys,
I need you're help, my PC monitor for some reason is only displaying half a screen the other half is all greyed out sometimes black, if I move the mouse over to the "dark side" it takes the same ammount of time to come back again so I know the desktop is there, I've tried reinstalling the graphics drivers this does not solve the issue, IT's also does this in the Bios, I would post a picture up for you all to see but I cannot figure out how to post pictures up yet..
Also if I unplug the monitor for 10minutes or so then plug it back in the picture is as normal then after a few minutes you can see the picture starting to distort again.
Please help. I dont want to have to buy a new monitor
Silly question here, but I'm running in SLI does the screen take half a picture from each card to make a whole picture???
Update.
For some reason the the picture has slowly come back and look normal again no odd lines, I'll keep an eye on it,
I have also tested both the graphics card seperatly and it done it with both so I cant see it being the SLI config?
